  1. hi!
    i've created a MPEG2 SVCD compliant file (480*576 25fps PAL 16:9) and created an XML. used vcdimager (vcdxbuild) to create the cue/bin and burned with cdrdao. when I open the SVCD in windvd, its aspect ratio is 4:3. what am i doing wrong?
    thanx!
    MO, US
    Very few players recognize a 16:9 flag on SVCD. The standard SVCD aspect ratio is 4:3, if you want proper playback on most players (both software and hardware) you should encode it as 4:3.
  3. and how to convert 16:9 to 4:3? i'm using flask 0.6 and CinemaCraft 2.50
  4. Set the destination aspect ratio in Flask as 4:3. Flask will do the necessary resizing and letterboxing.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. In CCE 2.5 use 16:9(add borders,encoded as 4:3)
    You will get the best result. If your using a 4:3 TV the borders added give
    your movie the aspact ratio without stretching.
    If you have a widescreen TV you can probably remove the borders, still
    keeping a good picture.
    Watch these examples
    [http://www.vcdhelp.com/forum/viewtopic.php?t=111846][/url]
