Hi,
I got a lil' problem. I always make pictures at the end of my SVCD that say something like "Please insert next cd". I create the pic in 768x567, the standard hi-res SVCD and save them as BMP. Now I insert them with Nero at the end of the CD.
When the SVCD is finished with burning, the picture has colored bares or vertical lines or blocks at the top or bottom.
What is this?? Shall I use another pic-format or what am i doing wrong?
I always set the right video mode (PAL or NTSC) in Nero, so this can't be the mistake...![]()
"Ich weiß, dass sie glauben, sie verstünden, was sie denken, was ich gesagt habe.
Aber ich bin mir nicht sicher, ob sie begreifen, dass das, was sie gehört haben, nicht das ist, was ich meine." -
Svcd is 480x576 and dvd is 720x576 for pal and 480x480 and 720x480 is for Ntsc. Use these sizes depending on if you are making an svcd or dvd. Also you may try using a Jpeg instead of a Bmp.
k, i try these sizes. but the jpeg wont work. i used one last time and it looked like a blured pot of salad...
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 14:19 -
Extra video top and bottom; black bars left and right
By koberulz in forum Newbie / General discussionsReplies: 27Last Post: 15th Oct 2011, 15:14 -
Why do some Widescreen Movies still have black bars top and bottom?
By the_importer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 10:09 -
errors on side of video, horizontal bars from top to bottom
By norcent33 in forum Software PlayingReplies: 2Last Post: 26th Jun 2007, 11:48 -
How to add a colored top and bottom for widescreen
By Jeff_NJ in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2007, 10:33
