OK, so now I have a 736mb UTi file, but I can't burn it to a VCD.
I can view it in VLC, but that's it. Quicktime Pro, Media Cleaner, Mpeg Tools, Missing MPEG Tools, more missing MPEG Tools. Nothing I throw at it works.
What can I do with it to make it a VCD?
Is this the second disc of harry potter by any chance?! Are you using os x? if so have you tried simply adding .bin on the end of the file name? You then should be able to use it is toast. This may help if not apologies.
yes, you are correct. I'll give it a try tonight. I just didn't know if this was some new media format or not.
I'll post again tonight if it worked or not.
Thanks -
I had the same problem so i also changed the extension to bin but it didn't work for me. i normally use vcdeasy to convert my bin files to mpg but it didn't convert. anymore more ideas?
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 10:11 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30
