I know that an MPEG file should be VCD compliant, but as we know, NERO accepts or will allow noncompliant MPEG files. I captured my file with these settings:
MPEG-1, Resolution: 352X240
Video data rate: 1150 Kbps
Audio bit rate: 224 Kbps
Capture Frame Rate: 29.97
Sample rate: 44100
Performance Level: 11 (it's usually set for 3 for VCD realtime capture)
The only major difference in this set up and the VCD realtime capture set up is the performance level. I've noticed that the performance level brings the audio and video in better sync together.
I am using Ulead VideoStudio and Nero 5.5
I am not crazy about the ATI Multimedia capture program because it takes to long when you press record to capture while Ulead is instant like a normal recorder.
I think it will work out for you but to be
certain you can do this:
Split your mpeg file into audio and video
and use bbmpeg to mux them again and check
if bbmpeg is set to videocd.
Use nero to burn a vcd compliant cd or a
non-compliant vcd which is also usually accepted
by a standalone-player.
Regards,
Will this crazy set-up work? (XBOX recording question)
By Goatman in forum Capturing and VCRReplies: 19Last Post: 10th Mar 2011, 17:34 -
Making BD Rebuilder work on a Mac
By Spoffo in forum Blu-ray RippingReplies: 0Last Post: 10th Mar 2011, 05:27 -
Anybody good at making title animation want some paid work?
By Mutt_CA in forum EditingReplies: 1Last Post: 16th Feb 2009, 23:29 -
Making my PC work with my Ovelia HDTV
By Hobson in forum DVB / IPTVReplies: 2Last Post: 11th Aug 2007, 13:47 -
How does AutoGK work for making SVS to avi files?
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 15:04
