Since I bought my DVD player I already tried burning 4 VCDs, all of them had problems.
Actually, the first three were from the same video file (a MPEG I downloaded on KaZaA), I tried all tips (found here) to convert it to proper VCD format using TMPEGEnc and VCDEasy. The last time I tried the problem was slightly better, it only halted 3s from the end. (all these three I tried on the same CDRW disc).
But this last VCD I tried is complete crap, I made a VCD from four separated MPEGs not reencoded in anyway, I just threw them in Nero and it reencoded the files (when necessary, some didn't need to). The menu worked fine, and the first MPEG played fine for like 2mins, then it started halting, and huge squares appearing, complete blanks at times, missing sound. The other three videos already started with problems.
My player is a Panasonic RV32, which I've found out to be a good player with very good recomendations.
So, what am I doing wrong?
Details: the CDRW disc is SKC, and the CDR (in which I burnt this last VCD) is TDK.
Just one other thing, all VCDs I burn have PBC on. And I don't like this one bit, cuz I can't tell the playing time (it doesn't show on the player display or on the OSD). Can I turn PBC off and still have menus and chapters?
I haven't and probably never use nero for reencoding but you could try burning them at a slower speed...that sometimes works. I am guessing that all of your vcds play fine on your computer? I prefer using tmpgenc since I can view it after I convert something.
tuco -
Yes... they play perfectly in the computer.
But do u own the exact same player? Panasonic RV32?
I tried using TMPEGEnc and burning with Nero at 4x, still got errors. -
Originally Posted by cdecherytuco
Video plays in the wrong aspect ratio by default.
By jimminy_kriket in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2010, 15:05 -
XVD4PSP 5.0-6.0 encoding for HD movies terribly slow on Win 7 64 Bit with..
By pectin232 in forum Video ConversionReplies: 2Last Post: 25th Nov 2010, 20:28 -
Sony Vegas 10 - Terribly slow rendering!
By Reventon in forum EditingReplies: 14Last Post: 30th Jul 2010, 04:59 -
Windows cannot see VCD, directory blank, but plays okay?
By ianlin in forum Authoring (VCD/SVCD)Replies: 8Last Post: 3rd Oct 2008, 15:17 -
VCD plays but has no audio
By rockydogg97 in forum Newbie / General discussionsReplies: 1Last Post: 12th Feb 2008, 02:07
