Hi everyone, I am trying to cut a captured movie in two using the source range feature so that I can put it on two cdrs, but when I move the bar where I want to cut it in half the whole program freezes and I cant do anything. I have never had this problem before so Im asking for help to resolve this issue. Oh yeah, I am using the registered version of TMPEnc Plus version 2.53. Thanks
dcapp1,
That used to be a known issue in 2.57 but I'm not sure about your version.
I'm using v2.58 and it works like a charm. It's a free upgrade so if you don't have any other issues to consider you might want to try that.Warning! I'm baaaaaaaaack -
If I go to the TMPGEnc site and download version 2.8 will it still be the plus version or will it be the free version because I want to stay with the plus version.
Go to the main Pegasys site: http://www.pegasys-inc.com/e_main2.html (download section) and you can get a free update.Originally Posted by dcapp1Warning! I'm baaaaaaaaack
Okay I got version 2.8, but the movie is still freezing up when I try and cut it. Any other suggestions? Thanks
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
