Can you capture with Huffy, with any other programs other than Virtualdub? I have a Canopus Advc-50 and it just won't work with that, because of the DV conversion I believe?
Will capturing with huffy codec even make a difference when capturing to a DV 2 AVI?
It should work with any capture card. I personally cap with HuffYUV with VDub and AVI_IO. It makes a big difference because it's lossless, the only lossless codec, other than capturing uncompressed. Perhaps it's an OS and WDM driver problem.
Not sure. I thought I read somewhere on the forums there was a problem with Vdub and some of the advc-100's?
I am running Windows XP Pro SP1.
I will try the AVI_IO. Thanks! -
Video Capturix also works with Huffy and you can select your capture driver and it also works with WDM, something I wish Virtual Dub could do...
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 13:56 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 21:01 -
huffy -> xvid
By geonuine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 3rd Nov 2008, 07:49 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 17:52 -
Problem exporting a file with HUFFY UV
By V.A.M in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 18:53
