I have a 91 min avi file (divx) that I want to put over to VCD. When I converted the movie yesterday I got a 3GB file before I ended the conversion since I thought the program crashed. The preview screen were standing still at the exact point when the movies ends. It also reported that I needed 4 hours or so before it was done, 60% of the movie was done.
To my big surprise the movie was there, but no sound.
So I started again, just to check that it worked, and after a few minutes I stopped and checked the result, still no audio. TMPGenc also said that the conversion would take 5 hours.
In the preview screen, it tells how much time have elapsed, remaning and actual time of the movie.
What I had was 30 min of the actual movie, running for 40 minutes and 4.5 hours left. The file was 270mb at this point. I tried TMPGenc version 12a, 12c and 12f all with the same result. After this I tried a Simpsons episode, which was 21 min long, and that took 23 minutes to convert with audio.
I have converted other movies with TMPGenc 12a with sound and no problems.
What should I do? The movie plays perfectly in WMP with Kristal divx codecs, and it stops when it's suppose to.
Got no clue what to do, please help.
Should I let it finish, and then do something to fix the problem? I'm using the standard template for NTSC from TMPGenc. If it's AC3 sound, how do I find out if the movie is using AC3 sound?
Regards,
Lars
Results 1 to 1 of 1
Copying a large MP3 audio file to 2nd CD-R once 1st CD-R is at capacity
By keypoints1 in forum MediaReplies: 10Last Post: 20th May 2011, 22:44 -
Finished my WMM project, saved as avi file-7.35gb. Now what?
By jbitakis in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2008, 12:27 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
How to stop audio/sound mp3 file from playing when video is finished playin
By lindylex in forum ProgrammingReplies: 3Last Post: 14th Mar 2008, 17:36 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
