I have a bin/cue file (the bin is 803mb). Is there a way to burn this using an 80 minute cd-r?
I thought I might have to extract the bin to mpg with vcdgear (when i did that the mpg played fine with windvd, but the video went really fast and out of sync with the audio in windows media player).
Is there a normal process for this, or should I just split the mpg from vcdgear and take my chances? What is the maximum amount of video this svcd could get packed on a 80 minute cd?
Thanks!
If the BIN file of the CUE/BIN set is really just 803 MB, you should be able to fit it on an 80min with just a tiny bit of overburning...
Regards.Michael Tam
w: Morsels of Evidence -
thanks for the reply, but i thought an 80 minute cd-r only held 700mb.
can you please confirm? -
It holds about 703 MB in MODE1 or MODE2 Form1 (i.e., 2048 bytes of user data per sector) --> CD-ROM.
It holds about 798 MB in MODE2 Form2 (i.e., 2324 bytes of user data per sector) --> (S)VCD.
Regards.Michael Tam
Thank you vitualis. So if I overburn the 803MB file, it should definately work, (since it is only 5mb past the limit)?
Thanks again for your reply. -
Yes, you can overburn by about a minute fairly safely (i.e., about 10 MB in MODE2 Form2 sectors).
Regards.Michael Tam
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
