hey sorry to be askin this and if im asking the same question that was solved many times but i looked and couldnt find a thread similar to this..
my question is, if i bought amd xp 2700+ and ripped a DvD and then encode it with TMPGenc, how long of an average time period would it take me to encode? like around 4 hours? please and thank you`
I have a 733 Celeron overclocked to 850 w/384 MB of RAM and I can do ninety minutes of video with that in just a little over four hours.
Available memory will increase your speed. So will DDR. If you're gonna upgrade start with at least 512MB and go from there. I'm waiting patiently for another 256 in the mail for exactly that reason -
It's hard to tell, like what motion search settings you have etc.
If you have a 1.2GHZ PentiumIII/Athlon now and it takes 8hours,
it will probably take 3-4hours with the new CPU.
But best value would be getting a XP2400 motherboard combo.
as a 2700 is just a tad better but cost twice as much.
http://www.pricewatch.com/1/306/4929-1.htm -
thnxs, well im actually going to upgrade and I want to rip/encode all my dvd that I got, i never knew DDR ram will do the trick and as for overclocking, well maybe later
, but umm i would love to have a chat with you online asap, because I am really interested and got some few questions to ask you
irc: dalnet
channel: #likwid8
anyone else willing to help me out here please join there, its only me in that channel... and or reply here thnxs.... for all ur help
Philips BDP 2700/05 - region code hack???
By MAC-IRELAND in forum DVD & Blu-ray PlayersReplies: 24Last Post: 30th Nov 2011, 10:00 -
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
Need BluRay player that does what Philips 2500/2700 does,but sells in USA
By ufcdave in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2011, 22:41 -
AMD Phenom X4 9500 vs AMD Phenom II X3 710
By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 21:03 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24
