just getting a new dvd re-writer and would like to know what the best tools are for converting. Any help much appreciated. (Don't really want a lot of coasters!!)
Cheers
Honky![]()
Tip1: First use DVD+RW disc (if they work on your dvd player)
Tip2: Try to find a single layer (DVD-5) DVD disc to backup.
Tip3: Use a DVD where the movie part is around 4-5GB
Use this guide by "Enemywithin"
This should strip down 5GB to the needed max 4.3GB.
http://www.vcdhelp.com/forum/viewtopic.php?p=315500&highlight=#315500
Now you can move on to DVD+R and probably make no coasters.
Defrag your HD if you think the vobs are spread all over the HD,
as it could make the DVDR drive having a buffer underrun.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
