  1. Hi,
    My friend has given me some movies in divx format, so I downloaded divx codec, and then this xvid codec he said it needed as well. The movies play but they are tinted green and they look all screwed up. All 3 of the movies he gave me are like this and he doesn't have the same problem so I know it isn't the movies themselves... Please help!
  2. yeah, me too have the same problem....i downloaded a movie in kazaa in xvid format. actually i've downloaded movies in this format and with the codec in the nimo pack it worked fine. but this movie doesn't work as it should. it's green most of the time and completely 'disturbed'...u can't watch it properly....i downloaded other xvid codecs from some other site, still no use...hope it's really some codec problem...cause the file is 700 mb large and it took me almost a week to download...
    please don't disappoint me...
    please help!
    thanks in advance,
    raycas
  3. Banned
    Dec 2002
    Somewhere I belong
    NOW I know the solution to this shit.
    I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
    You can install xvid codecs from here:
    http://www.divx-digest.com/software/xvid.html
    Then I installed all DivX codecs separat (Not from Nimo).
    http://www.divx-digest.com/software/divxcodec.html
    After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19. Install Nimo from here:
    http://www.btinternet.com/~nimosiro/
    Now all should work fine!
