How does dvdr compare to an actual dvd? Can the video and sound quality really be duplicated exactly? For those of you who have purchased dvd writers, is it worth it?
Originally Posted by Maverlck32
sometimes you have to re-encode the movie to fit it in one DVD-R but if you do it with CCE you have absolutely great quality movie(99.999% of original quality... maybe not that much but close 8) ).
I have now done more than 50 movie's in one month! So YES it is worth it -
CCE=Cinema Craft Encoder , one more question, how long does it take you to do a movie? -Setup Time-? -Actual Conversion Time-?
with CCE 2.5 I can get 1.4-1.5 realtime encoding speeds... it up to you how many passes you want to do... for example if you have 2 hour movie and you are using CCE with 4 passes then it takes about 6-7 hours to encode...
then you have author it with DVDmaestro (or other) it takes about 30 min... and then burning 1X speed takes 1 hour and 2X speed takes 30 min
so its about 8-10 hours job.... but it's nice to encode when sleeping
Zzzzzzzzz -
well summed up but I might add that 2 pass on CCE is very good quality too so (if you cannot wait or prefer to sleep in silence).
Oh... and don't forget, many discs are single layer, or small enough to have unwanted material stripped out, therefore NO loss in quality.
Is it worth it? To me, definitely. Even if my writer broke tomorrow, I would get another by the end of the week.
Compression: How much video quality loss?
By Djard in forum Video ConversionReplies: 9Last Post: 17th Jun 2011, 15:45 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 14:56 -
MKV to AVI without quality loss
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 09:51 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 01:03
