Is there anything I can get or do to clear up bad quality mpeg's I mean I put it on vcd and I can barely see anything. Is there a program I can get to make the encoding go faster and to clear up movies.
It could be a low bitrate or a crappy source file that you used to convert into a MPEG file.
Remember:
Crap In=Crap Out -
Yes, if you TV has noise reduction feature.
Digital Noise reduction features are normally added
to SVHS VCR, and Tv, but rarely on DVD player. -
Is there a good encoder I can get to tweak the mpeg to be in pretty good quality like close to vhs or dvd quality and if so some things I can to make it look better. and I would like an encoder that encodes them faster but in good quality.
CCE is the end all if you can get your hands on it. No matter what you do though, your going to have bad quality with VCD. It needs a VERY clean source (i.e. DVD) to give good results. Try using CVD, or SVCD, or higher. If you standalone doesn't support them, I'd suggest it's time for an upgrade...
Impossible to see the future is. The Dark Side clouds everything... -
With bad quality mpegs, you have the same alternatives as with bad quality avis: Filtering. Some people make miracles with filters!
It is not an easy task. It takes time and needs advance knowledge. Don't expect a "hit & go" solution.
For example, if you manage to load your mpeg to Vdub (with frameserving or direct, it is possible with frameservers/plug ins, etc), you can use all those wonderfull filters this amazing program offers. You may fix some things that way. Then re-encode with CCE or TMPGenc to a new mpeg and it might look visually better the source.
It isn't easy and fast, but it is possible. Are you prepared for this "adventure"?
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
bad quality on youtube
By stansvid in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 20:57 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad quality downscaling...
By Emillister in forum Video ConversionReplies: 33Last Post: 29th Aug 2009, 12:48 -
Bad quality with VobSubs
By Xavier in forum SubtitleReplies: 1Last Post: 19th Apr 2008, 02:31
