only askin this cuz..windows media player aint all that great (for me anyways) sum movies i play back in windows media player are a lil blurry but if i just prewivew em by right clickin the file its fine.
so what is the BEST avi player to use to watch movies?
If they're divx then you can use divxplayer..it's not bad, or for mpgs and svcds i use a player called VideoLan. Look in the Play option on the left hand side under how to and it'll give you a list of good ones.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Whats a simple software DVD player that just works !
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 15:20 -
whats the best software to convert flv to avi
By videodude1966 in forum Video ConversionReplies: 1Last Post: 10th Feb 2011, 03:16 -
Whats the best Bluray to Avi/Xvid converter
By adamf154 in forum Blu-ray RippingReplies: 4Last Post: 23rd May 2010, 21:22 -
whats the best dvd player for divx/xvid playback?
By saxon in forum DVD & Blu-ray PlayersReplies: 19Last Post: 19th Jul 2007, 11:55
