can u have lik and MP3 or WAV file run in the backround of the menu screen????
If you use DVDiT-PE, then you can have .MPA or .AC3 or LPCM music play in the background for a menu. MP3 and WAV files will not.
can i convert mp3/wavs ti ac3 ...... or other eligible formats?
by the way, when i select BUILD DVD, i use a cdrw 80min, the dvd files fit for its under 700MB, but the cd never works...must i use DVD-R.....
please suggest sumtin....... -
can u convert the MP3 files?? with wut if u can??
by the way, when u select BUILDDVD to DISC, must u use a DVD-R even though the files fit under 700MB?? i tried it but it never seemed to work...
please suggest sumtin -
You can use BeSweet to convert a .WAV file to either .AC3 or .MPA.
I haven't used DVDiT for quite some time (found it too unstable), but you should be able to select what format you want to burn to. -
my dvd player supports all that svcd/vcd stuff, but when i use dvdit to make dvds, it never works???
To your question about DVDit and burning/authoring to a CD-R...the "DVD" that you made onto a CD-R will NOT play on any set top DVD player. The disc you made is only playable on computer. As of right now the disc you made (Mini-DVD or DVD-CD) does not play on any DVD player. Perhaps in the future. For now burn to DVD-R.
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 16:56 -
dvd with menu with music
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 8th Jan 2010, 21:58 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Menu Music Choppy
By benbar in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 12:49 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
