I seem to have lost the black art. My lip synch is out when making svcds using TMPGEnc with SCMX tool. Any ideas?
Results 1 to 10 of 10
carpe diem maņana
These guides address audio synch:
--Same amount of synch loss throughout your video
-- Synch loss increases throughout the videoHello. -
Thanks for that but this is really weird. In Windows Media Player the lip synch looks OK but after I've burnt it, the sound is slightly ahead. HELP!! I'm using Nero by the way I've done dozens successfully before.
carpe diem maņana -
Did you encode before you let Nero get ahold of your file?
Hello. -
It was Bend it Like Beckham. I used SmartRipper to rip the vobs, then avi2vcd, then TMPGEnc with SMPX (or whatever tool) THEN Nero
carpe diem maņana -
What exactly does the phrase "TMPGEnc with SMPX (or whatever tool)" mean? Did you use a TMPGEnc template or not?
Hello. -
Sorry it is garbled. I wrote it after I came back from the pub!
I used the PAL VCD template. I used the SCMX audio tool from within TMPGEnc. I've been using this with great success for weeks when ToolAme started playing up.carpe diem maņana -
Originally Posted by fazza8
by the fact that the SVCD was in sync before you burned it means that the burning process made it outta sync....or could be the media
also, how fast did you burn? 4x should be max.... -
The mpg file is in sync but the burnt CDR is slightly ahead on speech on my Mustek 520 DVD standalone and my fujitsu pc DVD player.
I burnt at 4x.
I use Tevion CDRs. I've done dozens of em with no probs.
Should I try burning 1x maybe?carpe diem maņana -
Tried at 2x (lowest possible) but still had sound ahead.
carpe diem maņana
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Divx Lip Syc Problem
By pete7769 in forum Video ConversionReplies: 5Last Post: 16th Mar 2008, 07:42 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
