Hi:
I am trying to capture video through a firewire from my DV camera.
Everything is fine except that I get jagged lines instead of straight lines.
I use a Sharp VL-PD3 camera and recorded at LP mode. I have SIIG 1394 3 port PCI firewire card. When I display on TV, lines are straight. Could you guess what might be the problem and how can I fix it?
It seems to me it is related to resolution, but even if at 320x240 preview
mode lines are distorted.
Thanks.
Thanks for your response. I use Ulead MovieFactory to convert the
AVI to MPEG. I tried FieldA, FieldB and Frame options. If I burn these
onto a DVD-R and display on TV, I get less jagginess, but it is still
there. Do I need to deinterlace before encoding to MPEG? I tried to
use the VirtualDub, but it hangs. -
It will help greatly if you can show us a screen shot. Sounds like "stair- step effect". My guess is that you have a broken capture card that captures with wrong field order. There are two ways to correct this:
1. If you capture with VDub, be sure to check Swap Fields option.
2. Otherwise, you have to use Avisynth's SwapFields() filter to correct it. -
Yes, a straight line becomes like a stair case.
I tried another firewire card, same result.
Could it be the cable? If not, then it is the camera.
I cannot get the virtual dub work. It is said
it requires Video For Windows interface. -
I can see the jagged lines on the DV Camera's LCD screen too.
So, I think there is nothing wrong with the capture.
It seems I need an encoder that has good deinterlacing.
Any suggestion?
Problem with motion getting jagged lines
By philflo in forum Video ConversionReplies: 2Last Post: 6th Mar 2012, 08:27 -
Edges look jagged, and lines across the video.
By killerteengohan in forum DVD RippingReplies: 18Last Post: 29th Jul 2011, 13:18 -
Jagged lines upon playback
By seven_deuce offsuit in forum Video ConversionReplies: 10Last Post: 17th Jul 2010, 08:31 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 22:35 -
No jagged DV to HD possible?
By chamo in forum EditingReplies: 8Last Post: 22nd Dec 2008, 17:49
