I have a big mpeg (900MB) which I want to burn on cd as vcd. I now need to split the file as the content is +80 min (about 90).
I have tried to split it with TMPGEnc but then the audio get out of sync.
Does anyone know how to do it? I just want to split the file whitout losing the audio sync!
Results 1 to 16 of 16
Dont know how to explain in english but it (the split) results in that the sound/audio and the movie/person who talks doesn't happen at the same time.
Which video file, the first one, ot the second one, or both?
Hello. -
I want to split the 900MB/90min file to two 450MB/45min files to burn on cd.
Which vido file is not in synch. the first video file, or the second video file?
Hello. -
Tommyknocker,
I have exactgly the same problem, it is the second disk that is out of sync. And ususally it is noticeable fairly quickly after the second disk starts to play.
Ed -
Then does the second FILE (not the disk) play in synch?
Hello. -
Now we are getting somewhere. Note exactly where in the original video your second file begins. Load the original video into Gold Wave. Select Edit-->Marker-->Set. In the Start Marker box, leave the zeroes. In the End Marker box, enter the start time of the SECOND video file. Select OK. Select Edit-->Delete. Save as a wave file.
Load the SECOND video into TMPGEnc as input video. Load your new wave file as input audio. Select Start. The resultant file should be your second video file with audio in synch.Hello. -
use a 900 meg -99 min cdr...find them all over the place if your in the uk try a local computer fair..that way u wont have to split files(just make sure yer burner will support them)
basser,
nice try but my burner will not do 99 min cdrs.
tommy,
to recap in my own words what you suggest is from the original and insync file split out the audio for the second portion using the known frame count where the first portion ended (that is 1 frame after the ending frame) up to the end of the file. Then in Tmpgenc load in the video for the second portion (which already exists from the original splitting) and the just extracted audio for the second protion and just simple remux them together again.
Did I catch your suggestion correctly??
Thanks,
Ed -
I just hope I understand what you are saying. As for the audio for the second file, you will extract it from the original video, but only from where the second audio begins to the end. Are we on the smae page?
Hello. -
Yup. On the same page. I was only confused by your earlier remark
What you were saying was to delete the first part audio. Then all that is left is the second part audio which is what is really needed.In the End Marker box, enter the start time of the SECOND video file. Select OK. Select Edit-->Delete
The last step was just to do a simple remux in tmpgenc. And then all should be well again.??
Thanks,
Ed -
Easiest way would be to demux the video, then remux with BBMpeg set to max file size of 500.
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
AVI mono movie too big to burn on to single layer DVD-other options?
By nzdreamer55 in forum Authoring (DVD)Replies: 7Last Post: 29th Apr 2011, 14:45 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 22:20 -
Adding subtitles to a BIG Avi file and then burn to dvd(?)
By Hal05154 in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 15:15 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
