okay, i can't understand what SSA does to my subtitle files..
example: i got subtitles for a movie and it's not in sync. i converse those subtitles to .ssa format with SRT2SSA or SUB2SSA.. i change the fonts and the size to what i prefer. and then i open the .ssa file in SubStationAlpha to adjust the timing. after i've done it, i put the adjusted file to VirtualDub like normally. BUT, the font size appears to small. and i mean SMALL! i tried to change the style in SSA, but nothing. same problem..so, what the heck it does to my file?
--< Willie >--
"if i could be like that..." -
yes i haveOriginally Posted by wiltzu
but i'll take a better look at it.. SUB2SSA does change the framerate, but i can't adjust the timing, if the subs are not synced from the beginning.. or i've missed the option in the program.. have to take a look at sometime..
--< Willie >--
Try to adjust the PlayResX PlayResY values. You may find them in the beginning of the script. Try to reduce them.
SUB STATION ALPHA 4.08 - For 64 Bits Systems
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 23rd Oct 2021, 12:51 -
Hardcoding Styled (Sub Station Alpha) Subtitles to Videos
By Eudorcas in forum Newbie / General discussionsReplies: 15Last Post: 11th May 2012, 04:57 -
alpha layer trigger
By Scott Hooson in forum EditingReplies: 1Last Post: 1st Dec 2011, 07:36 -
Problems with Alpha Channel
By CKyle in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 16:02 -
Sub Station Alpha will not install
By slobjones in forum SubtitleReplies: 2Last Post: 14th Apr 2009, 15:55
