I've been using GraphEdit for a awhile now to extract AVIs from WMV files and I've run across something a little strange.
I've just extracted an AVI from a WMV using the method described here at VCDHelp's FAQ. I used both the AVI Mux and File Writer filters to write the stream to an AVI. When I play the AVI, it shows a running time that is roughly twice that of the original file (9:42 vs. 19:27).
Is this an issue with the AVI file or WMP (which I'm using to view the AVI file)? I suspect (and am hoping) that WMP is calculating the running time incorrectly.
I'm deathly afraid of running into audio sync issues, despite encoding audio and video separately and muxing them later.
Does anyone actually respond to posts on this forum?
I guess the wrong timestamp is due to the variable framerate that WMVs employ. That's the only logical explaination I've been able to come up with. That assumption leads me to yet another question:
What happens when this AVI is encoded in MPEG2? Can the encoder correctly encode an AVI to reflect the original running time?
editing or converting 24fps mpg and retain original length and playback
By MisterRPH in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2011, 23:36 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
The length of video remains the same as original after splitting
By Moth Queen in forum EditingReplies: 1Last Post: 25th May 2011, 08:26 -
Convert from wmv/asf to mp4 - results in zero length file
By techiejustin in forum ffmpegX general discussionReplies: 1Last Post: 25th Apr 2010, 23:56 -
Slow down the video to roughly fit with the audio?
By smd721 in forum EditingReplies: 4Last Post: 23rd Apr 2010, 06:55
