  1. I want to converde a Film from DivX5 to Vcd. When i try to open the file with Virtual Dub i get following message :
    Couldnīt locate decompressor for format DX50(unknown)
    Virtual Dub requires a Video for Windoes (VFW) compatible codec to decompress video. DirectShow codecs,such as those used by Windows Media Player.are not suitable.
    Witch codec did Virtual Dub want and where can i get it to serve that problem?
    Divx 5 is installed and the player shows the avi.file.
    Hope you can help
    Tnx
    Maiden29
  2. Virtual Dub cannot save .mpg for VCDs. Use TMPGEnc, as for the error messege, make sure you have the DivX codec from www.divx.com, and reinstall it.
