http://www.jplt.com/nero_faker.ttf
I follow the link for the invisible font. Now what? Do I overwrite a certain file? Any help is appreciated. Thanks.
thisisdirty@hotmail.com
Problems and Tips
How can I remove the menu-text that Nero adds?
Use this invisible font, it let you bypass some of the text that Nero forces you to put onscreen.
install font as any windows font i guess and select it -
I looked into that option, but it doesn't give you the option in Nero to choose the font. Thanks for the response. Anyone else?
checking for invisible pdf watermarks?
By UncleBose in forum ComputerReplies: 8Last Post: 13th May 2010, 14:26 -
Invisible earpiece solution?
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Dec 2008, 22:36 -
ConvertX mystery: invisible files ??
By Seeker47 in forum Video ConversionReplies: 5Last Post: 22nd Sep 2008, 00:59 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
Why is my external burner invisible in DVDFlick?
By mavrickjubei in forum Video ConversionReplies: 1Last Post: 26th Mar 2008, 00:53
