Out of interest I wanted to ask if there is really a visible difference (keyword capturing) if one would use these, often called professional, gold-plated composite leads?
i'd guess no. the quality of the cable itself can matter in terms of picking up interference, but that's mostly shielding. also make sure it's a 75 ohm cable, not a cheap audio cable. video signals are higher bandwidth and have some ghosting/reflection effects if the impedance is wrong. if you're running it through several components (e.g. antenna signal-> vcr composite-> receiver -> computer) it could make a difference, but even then i wouldn't bet too heavily on that. but using a double-shielded 75 ohm cable might. but if you can get them for like $1 more than a regular one, i suppose it couldn't hurt. http://www.allelectronics.com has some 3xRCA gold, one of which is a decent video cable, 6' long, for about $4. have i noticed a difference in quality from my vcr signal since i got those? no, but they did simplify the mess of wires behind my entertainment center.
I agree, just get a quality cable and don't worry if it's got gold connectors. The advantage of the plating is probably just resistance to corrosion.
Gold Plated Vs Normal Cables
By amira in forum Capturing and VCRReplies: 19Last Post: 15th Nov 2011, 13:02 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 14:35 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
dvd editing leads to unacceptable results
By jamesgig in forum DVD RippingReplies: 7Last Post: 18th Sep 2008, 20:42 -
By jamesgig in forum DVD RippingReplies: 2Last Post: 7th Sep 2008, 00:49
