Hi there,
I've been doing various captures, rips and conversions for a while now and am fairly confident and happy with the results. However, every now and again I have problems with field interlacing.
As a rule I capture SVHS (using huffy) at, or rip and resize to, 352x576 (480 for NTSC DVDs) and then encode to a SVCD compatable MPEG2 stream.
What difference would it make if I de-interlaced before MPEG2 encoding (other than presumably preventing the occassional problems I have) and which method would give the best results - if it is at all advisable?
I await your knowledgable answers and comments![]()
Some purists feel there's no adequate way to deinterlace. Blending fields isn't enough so a smart bob or smart weave or some other time consuming algorithm such as Smart Deinterlace filter for avisynth or vdub must be used. see http://nickyguides.digital-digest.com/interlace.htm I display my Divx and Mpeg2 encodes on a projector and large computer display so I capture to Mpeg 2 I frame with my ATI AIW in progressive mode. I never have to deinterlace with software which for me would never be worth the time invested. If you are going to always display on a TV keep it interlaced and don't worry about it. If you use computer displays alot don't ever capture interlaced to begin with.
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33 -
Interlace or Bitrate ??
By garylanders in forum Authoring (DVD)Replies: 14Last Post: 4th Jan 2011, 06:14 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 11:20 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 09:46
