I've been messing around on VCDEasy and have pretty much got it sorted, but for one problem.
I have created my menus in Photoshop and converted them to MPEG Stills. I then create my VCD .cue file and use Nero 5.5 to burn it.
However, when I play the VCD in my standalone player, the menu's appear corrupted. The BMPs I use for my menus are 640x480. Is this the problem (i.e. do I need to create menus that are 352x288). The tutorial on this site used 640x480 stills.
The Dude
"I'm the Dude, man....so that's what you call me. Either that or Duder, His Dudeness or El Duderino, if you're not into that whole breavity thing".![]()
Go to the VCDEasy website and the beta page (you will have to register) and download MJPEG Tools 1.6.0-rc2. Unzip it to the MJPEGTools folder under VCDEasy.
It should fix the problem.
Regards.Michael Tam
w: Morsels of Evidence
Easy way to set DVD to play next file instead of returning to menu?
By Calidore in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2012, 18:04 -
MP4 corruption Need Help
By yus in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:37 -
Creating a menu pattern for easy authoring
By pbear23 in forum Authoring (DVD)Replies: 0Last Post: 1st Oct 2008, 22:09 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
DVD Motion Menu Buttons (Free & Easy)
By ImaWeTodd in forum User guidesReplies: 31Last Post: 28th Jan 2008, 16:12
