I would like to start making VCDs/SVCDs and have downloaded some software in prep (virtualdub; TMPGen). I have some questions however about the required codecs. I understand this is dependant upon the file to be converted and what you want to convert to, but I hate packs, and dont like the idea of installing files I dont need. I guess my questions focus mainly around Nimo:
First, does nimo include a MPEG2 codec? Do I need this codec for TMPGen to work? Or just to preview the files I made?
Second, does nimo include a windows media audio v2 codec? Does anyone know of a seperate one for this?
Finally, and of most interest to me, I have read on other message boards that nimo may have negative affects on encoding and conversion, such that the quality of the output is reduced. Has anyone experienced this?
I have a feeling the answer to these questions will be, if you dont want nimo, use g-spot to figure out what you need depending on the files you are using and download each one seperately...
Any references to other available pacs will also be appreciated.
I'm all new to this, and any help is appreciated.![]()
My DNA Lives By Manipulating Me. -
I have been using Nimo's Codec Pack for some time and can only say good things about it.Just install the pack ..its not that big of a file.......or go with the Lite pack (1.19mb).
Check this out for contents of his Pack:
http://www.btinternet.com/~nimosiro/"Today is only yesterdays tomorrow" -
hey fubuki--i have had good luck with the nimo pack.
no u dont have to have it for tmpg to run............
if u do install it----i ran into problems with the file mmswitch.ax.
u will find this under c\windows\system
if u dont have a morgan multimedia capture card---DELETE!!!!!!!!!
it took me hours to figure that out--im running win98se..........
anyways---that was my experience---(ps.--nimo codec is good)lots of codecs...and a couple of tools---tsunami filter pack is cool for tmpg as well...
mail me if u have further questions------good luck,
jeff
Scanning 35m negatives to image
By LisaElifritz in forum Newbie / General discussionsReplies: 15Last Post: 2nd Apr 2012, 04:38 -
Song Of The South remastered from the original negatives
By Cherbette in forum Latest Video NewsReplies: 19Last Post: 7th Oct 2011, 21:34 -
photo negatives scanners
By didikai in forum Newbie / General discussionsReplies: 27Last Post: 22nd Jan 2011, 20:15 -
Looking for a conversion software that uses Dshow/VFW/ACM codecs
By giuliojiang in forum Video ConversionReplies: 2Last Post: 9th Jul 2010, 08:28 -
JPEG lossless negatives ???
By piano632 in forum ComputerReplies: 4Last Post: 13th Sep 2007, 16:43
