Hi, I'm wondering if anyone can assist me?
I make occasional interactive CD-ROM's with video encoded at standard VCD specs of 1150kbps via TMPGEnc which plays OK on Windows 95+.
If I encode the video (VCD) 'out of spec' at about 2,500kbps, would it have greater clarity and run fluently on a PC with Windows Media Player 6.1/6.4 or better?
Thanks for any advice which may be forthcoming!
If you do it right it and if your source is good enough it should look a bit better. It should also work fine on most computers using media player. If you only want it to play on computers you may wanna checkout divx or some other mpeg4 compression.
Are you using Macromedia Director's MPEG plugin to play the VCD in your interactive multimedia? The plugin should play MPEG-1 of most bitrate well as long as your CD-ROM keep up with or it will result in jerky video.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
What's the new standard?
By wild4trv30 in forum EditingReplies: 6Last Post: 31st Jan 2010, 11:39 -
Standard DVD in HD
By killerener99 in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2009, 06:14 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
