I've downloaded a Sci-Fi series off the web and the programmes are DivXwith AC3...i had no problems to begin with cause i had AC3 codec installed and they played fine. Just recently i have bought 2 games and unless i uninstall the AC3 codec they crash to desktop!!!
Anyway i want to convert the DivX files to another format and i've read the guide on here but have a question.
The guide says strip the audio out as a .wav file, when i reencode, is it better to use this .wav file or to convert it to a MP3?
Also am i better to convert it to SVCD or VCD, will i lose quality if i convert to VCD?
The best thing for you to do if you're just going to watch these files on your computer is to only recode the sound. To do this you need to strip off the sound using VirtualDub. Convert the file to a Wav file using Headac3he or Bsweet or Azid or similar.
Then select wav audio in virtualdub and load the wav file select your required compression (mp3 is probably best). Select direct stream copy for the video and save the as avi.
EasyVisit the home of Fuzz
http://www.nobspangle.co.uk/ -
Cheers Nobspangle,
Your the first one on any forum whos written any sense,
Once again cheers m8!!!!
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
