Hi,
on some PCs (not my usual one) with W2K or WXP the MPG files produced by TMPEG are at least 15 % to big. All settings are Standard so 80 min VCD should result in 800 MB video, but itīs 930 MB. Whatīs the problem ? On some maschines this happens, on some not (and i think i installed the same codecs on all). By the way: divx-movies with xmpeg have the same problem...
Luigi
depends on how you encoded your mpg....2 pass VBR will give a more predicatable filesize, while CQ VBR will not
I always work with CBR, thatīs the strange thing about it.
And a conversion on another PC with absolutely the same
parameters works fine...
Best Quality Video Produced From A .MOV file
By Nick12 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2011, 21:10 -
BDR produced on a 4.6 GB file...fritzi?
By New Bee in forum Blu-ray RippingReplies: 9Last Post: 4th Feb 2011, 10:38 -
VHS Camera Produced Strobing-Can I Remove It?
By Anonymous8743 in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2009, 19:01 -
ffmpegX says it's finished converting, but nothing is produced!
By alexliz in forum ffmpegX general discussionReplies: 3Last Post: 12th Dec 2008, 14:16 -
Codec issue for my clients playing a DVD I produced..
By plemal in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2008, 16:34
