After I have finish capturing from my analog camcorder as AVi file, I can not import it to Adobe Premire. A dialog pops up and saids (compression format unsupported) whenever I try to import it. I s there anyway I can do to fix this problem? if yes, how?
Thanks in Advance
KK
Hi, one solution is to use a software MJPEG-decoder.
http://www.morgan-multimedia.com/
or http://www.leadtools.com/video-codec_download.htm
or http://www.jpg.com/video/mjpeg.htm
well I prefer the morgan-codec, but it is just to choose on of above.
Take care.
Premire Pro CS5 Export does not work with iPhone Anymore
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 17:38 -
best export setting in premire pro CS3 for youtube
By yunakokimama in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 18:09 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02 -
how to export MPEG4 from Premire Pro 2?
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2008, 01:36 -
adobe premire pro CS
By pantsdavies in forum Software PlayingReplies: 58Last Post: 15th Dec 2007, 21:27
