  1. I try to make a 46 minute project and when I output the file, it stops at 18:54:11 which is 18 minutes, 54 seconds and 11 frames. Does anybody know how to make the whole 46 minutes?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    install win xp or win2000 - convert your your drives to ntfs ..
    what compression are you using with premiere anyhow?
