hello!!!! I need help, please... I have authored my VCD with menu, intro, and chapters with numeric interactivity, and it works fine in my standalone player, but... when I have tried to play it in my PC (win98 and XP) it doesn't work, neither with WinDVD nor .dat files with media player... ! and the worst of all... I cannot copy the .dat files to my computer!! I get next message: 'not a valid MS-DOS function' !!!!
anyone can help me?
Thanks!
Media Player (tried just about all versions) CAN play .DAT files directly from the CD's MPEGAV folder--NO PROBLEM.
If you're having a problem, something else is probably the culprit. Could be DirectX corruption, some other codec interfering, NO MPEG1 codec installed (not likely unless you're still on original Win95), driver/OS conflicts, deleted components, background tasks usurping cycles, viruses...
All those sorts of problems should be sorted out anyway so that your system runs smoother.
More Info, please.
I know that Media Player can play dat files. But it does sometimes have problems with them. I have a heap of vcds of music videos, which are .dat files and I never had any problems playing them until recently. The latest vcds play fine for 15 or so songs, but there are always 2 or 3 songs that Media Player doesn't recognise.
I know it makes no sense.... the files are exactly the same as all the others, and if you play the vcd on a dvd player they all work perfectly. Even playing them on the computer using powerdvd, they work perfectly. But Windows Media Player refuses to recognise some of them. So it's a totally illogical problem .... but I know that it is a problem that does exist.
So all I can recommend is either try playing them using powerdvd .... or convert them using AVS videoconverter and then they should work on Media Player
If a DVD/CD will only play on the computer...
By LellyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2010, 08:38 -
What do I use to play a VOB file on my computer?
By truebluepup in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 13:28 -
Burned DVDs only play on my computer
By kissy in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2008, 13:48 -
Play my MP3's from Computer to My Reciever
By mn072065 in forum Media Center PC / MediaCentersReplies: 9Last Post: 8th Nov 2007, 21:47 -
Can you play HD Divx files only on computer?
By chin569 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2007, 12:19
