Following the newbie DIVX to VCD instructions, I check the CDRDAO box under settings and it says to restart VCDeasy. So I do File, Exit, and restart VCDeasy. But when I click on settings again, the box is not checked and I cannot select my burner on the VCD page. Any suggestions? I've got Nero, should I just use that? Thanks.
Using a Lite-on 48125w 48x12x48 drive.
Results 1 to 1 of 1
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 21:20 -
How do you get VCDeasy to work on Windows 7 Ultimate (32bit) ?
By DragonLord721 in forum Newbie / General discussionsReplies: 10Last Post: 24th Nov 2010, 10:44 -
Intermittant Subtitle Integration
By follz20 in forum SubtitleReplies: 4Last Post: 31st Jan 2010, 03:54 -
New codec integration in FFDShow
By werner77 in forum ProgrammingReplies: 0Last Post: 26th Nov 2007, 17:39 -
The July Integration Ban and DVD Recorders...
By tbfl in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st May 2007, 13:45
