I'm planning on making a few movies, each half to be on one disc and each half almost an hour in length in the ntscfilm svcd format, 2pass vbr. I know the bitrate will be quite low (in the 1600's), so I'm planning on using the soften block noise function in tmpgenc. If the source has very little block noise, will this option really do much to the block noise at such a low bitrate, and if yes, what level of softening should I use? Any suggestions would be really appreciated.
407
Results 1 to 1 of 1
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 09:42 -
Digital block out
By homie241 in forum RestorationReplies: 9Last Post: 21st Apr 2011, 06:40 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57
