I would like to convert some avi files to vcd but the frame rate for the files is 14.985. How can i convert these files so that TMPGEnc will recognise them as pal or ntsc??
Start TmpGenc, cancel the wizard.
Then in THIS order:
Select your video and audio files.
Click load, and select the template that matches your requirements.
If you need to change any settings and they are greyed out,
Click load and select unlock.mcf from the extras folder.
Click start.
from 14.xxx fps I would suggest NTSC at 29.97fps is the closes simple multiple to get the best (smoothest) playback.
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 04:20 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 12:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24
