hi again i asked this question before but i am having problems with it again so. i use virtual dub to cut my divx files inhalf so they can fit on a cdr as a vcd but the audio is like way off from the video for some reason but the last time i asked this someone told me that i had uncompressed audio and they told me to load avi, select video-direct stream copy, select audio-full processing and set audio conversion to 44.100 so i did that and it worked great but now it is not working anymore i am doing the same thing but the audio is still messed up is there anyother way to do this or am i just still doing it wrong? thank you
select direct stream copy,select frame rate,select audio video duration match,save new avi...see if that works.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
