...REALLY APPRECIATE IT.....
ok, i downloaded a video...SPIDERMAN..... non-interlaced 4:3 525 line (NTSC 704x480)....i no its in VCD format, i wanna make it a SVCD... i tried it with TMPENC but when i burned it with nero it always came out buggy on my dvd player,,, MY DVD PLAYER DOES SUPPORT THAT STUFF..... the file is 1.3 GB, i only tried lik 25mg on an 80min CD-rw, now wut i want to do is make aSVCD on a DVD-R cd with nero and tmpg, if someone could provide those steps id appreciate it, thanks.............
this will create a dvd correct? it will need a dvd writer as well? i have a dvd writer, will nero automatically detect it and use it as a dvdrw?? i really dont feel like messing up more dvd-r's so is this info all correct?
If you have a CD burner, and the original is
then that SHOULD be valid for DVD-video, all you should need to do is author it. Use one of the many gudies in the authoring section of this site.non-interlaced 4:3 525 line (NTSC 704x480)...
although 704*480 IS a valid resolution for DVD video. some authoring apps will not accept it and want 720*480. In that case you could try DVDPatcher, or re-encode with TmpGenc. Again, look to the guides or search the forum for more info. -
why not just rip the DVD and encode straight to DVD compliant mpeg for DVD-R or CVD mpeg2 for SVCD?
Combining synched sound with video - total absolute newbie
By Povster in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 17:37 -
Total newbie needs help urgently (AVDHC -> DVD, with complications)!
By sebkni in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2010, 14:11 -
Total Newbie- Need help Premiere Elements 4- Two cameras Rendering
By VitalExpressions in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 22:53 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 12:28 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 13:24
