I am having some problems with the audio 3.11 alpha codec and virtual dub.
I wanted to compress a video file with virtual dub (I have done this before but a long time ago), so i tryed to remember the steps I took the first time. I got the video compression to work fine but when it came to the audio i had some problems.
I remember that i used the MPEG Layer-3 compression 128 kBit's 44,100Hz Stereo at 16KB/s the first time (i even opened one of the first videos i compressed to make sure) but i couldn't find that same setting in virtual dub, and i even clicked on the show all formats tab.
So i went to the guide i used the first time and it said the same thing, and it also said that i should have the divx 3.11 alpha codec installed for it to work (which i have). so i uninstalled the codec and reinstalled the codec just to make sure but nothing happen. i still couldn't find the audio compression i was looking for.
So does anyone know what is worng!!!!
Please help
Thx Alman
Downloading and installing the Nimo "Lite" Codec Pack should solve your MP3 problem.
http://www.nivelvirtual.net/downloads/?id=364
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 14:03 -
SOLVED: Can't Import AC3 audio in Virtual Dub 1.9 Stable
By mlong30 in forum EditingReplies: 2Last Post: 15th Jan 2011, 02:12 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 19:00 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 13:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45
