Say I'm encoding some audio using SoftEncode and I'm encoding to 2/0 (2 channels) at a bitrate of 128. I'm assuming that the 128 is the total bitrate for both channels. Is it?
Now let's say I'm encoding some audio and encoding to 3/2 (5 channels). Do I need to encode at 320 bps to get the same audio quality as above?
192 for 2ch
384 for 5:1
are the normal bit rates ...
128 is a bit low -- i would use that only for speech in 2ch ..
the bit rates stay the same if you use LFE enabled or not .. -
Thanks, BJ_M, the numbers I picked were just hypothetical, but glad to hear your recommendation. From your post, it sounds like the bitrate is the aggreggate for all channels.
Thanks again.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
AC3 vs. MP3 at the same bitrate
By wallywalters in forum Video ConversionReplies: 5Last Post: 11th Feb 2011, 10:21 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
trying to edit ac3 bitrate of mkv
By dgizzy in forum Newbie / General discussionsReplies: 8Last Post: 11th Dec 2008, 14:14 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11
