Ok, Am i screwed?
I have a Centrum Libra DVD-player, which is region 2 codec. So i downloaded the update and everything and burned it to a cd-r.
I putted it in my DVD, everything seemed to be going fine, it just told me to not turn the switch off under the process, as it could result in that the dvd-player would be unable to use, permanently...so...i let some time go...and a screen came up where it said, in the end, that the update had been successful or something..HOWEVER...NOW THIS HAPPENDS:
in the box it tells me to turn my dvd off and then on again....i try to do this by the remote...but it seems like the dvd has locked itself up...so i wait a minute or two and try again....again nothing...i try to press the clos/open button nothin....so i see no other option that to turn it iff, by the REAL powerbutton(switch or whatever its called)...so i do so...AND I`M FUCKED (?)
MY DVD_player is DEAD....the only thing that happends when i push the powerbutton is that something in the lcd background happends...nothign special...it doesn say anthing on the lcd....the poerbutton doesnt become red, as it always does....NOTHIN...plz help????????!?!?!?!?!?!?!?
Am i screwed?
Results 1 to 1 of 1
Major synchronizing problem please?
By tendra in forum Video ConversionReplies: 2Last Post: 31st Aug 2010, 12:28 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 16:18 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 12:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
