  1. What is AC3 sound? Is it dollby surround sound or Dollby Digital or something different? Can you put that on a VCD?
  2. AC3 is another name for Dolby Digital. The VCD spec does not allow for AC3 sound on compliant discs.
  3. What kind of discs can you put Ac3 sound on? Svcds or do they have to be DVDs
  4. SVCD have Mpeg1-Layer 2 audio
    "Today is only yesterdays tomorrow"
  5. What does that mean? Do svcds only support two channel audio?
    Can you put AC3 on a svcd?
  6. So, the only real benifit to having Ac3 audio is that you will have a better quality wav file when you convert it seeing as though all players dont play the format? Am I understanding this properly?
