I know that VirtualDub does not support IEEE1394 DV capture, but does it support EDITING DV-AVI video file ? I could not load these types of file since it asked for specific DV codec. Any advice, thanks you very much.
If you use MediaStudio/VideoStudio to transfer the DV stream, you will get a DV Type-1 AVI, which means non editable video in Premiere, VirtualDub or any other video software which is Video for Windows based. It uses Ulead Video Capture plug-in which you can't change.
You will need to install a Type-2 VfW DV codec (Adaptec, MainConcept) and convert your Type-1 file to Type-2. -
in video studio and media studio you can set you save file options to a dv type 2 avi. Then you can use the file in virtual dub. I think you need the panasonic dv codec though to be read in vdub, doing a search in the forums you shuold find a link. If you are just going to direct stream and frameserve to tmpgenc that is all you need. But if you wish to save the edited dv you will want the mainconcept dv codec. Hope this helps...
You can try using AviSynth and use DirectShowSource(...) in the avs file. Open the AVS file in VirtualDub.
Do a search for Canopus DV File converter, which will convert losslessly between various DV formats.
New to editing with VirtualDub
By xNesX in forum EditingReplies: 2Last Post: 18th May 2011, 23:56 -
Editing Lagarith AVI in VirtualDub
By HDClown in forum EditingReplies: 2Last Post: 25th Apr 2010, 21:20 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 28th Apr 2009, 23:37 -
Apple Quicktime HDV to AVI,or at least a windows compatible editing format
By SuperDre in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Mar 2009, 14:58 -
Editing AVI, VirtualDub Error, Codecs not working.Can i delete afew scenes?
By UmmAddan in forum EditingReplies: 5Last Post: 23rd May 2007, 05:29
