I don't know what the hell is going on, when i'm trying to convert Mpeg to Divx 3 low-motion with VirtualDub, file's getting even bigger instead of getting smaller, like 426mb mpg = 650mb avi (divx3).
What i do wrong? What setting should i change, cause i'm leaving all default.
Any help would be highly appreciated, otherwise i'll use crappy wmv.
If you know any other mpg to avi converters tell me, i don't care which one i'll use i just need reduce the size without changing the quality all that much.
I've ben using:
o o o o o o o o o o o o o [40] key frames (default is 20)
o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o 100%
o o o o o o o o 800kbits o o o o o o o o o o o o o o o o o o o o
on a 1 minute encode, it's under 4MB in size.
Does that help ??
also, what size are you encoding to, 352x240, 320x240, 640x480, etc. ??
-vhelp -
I tried divx3 , divx4 and xvid its still have bigger size then mpeg have.
And size is same as the mpeg one, which is tv show so its probably 352x240 or 320x240. Codecs doesn't have resolution setting anyways.
Ho to get VirDub x64 plugins to work?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2016, 21:14 -
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 11:04 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 12:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 20:59 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30
