I used dvd2avi to make my ac3 file and my d2v file. Then I used TmpgEnc to recode my vob files and make them smaller. All went well. Then I used DvdMaestro to try and author this DVD. When the ac3 file and the m2v file are loaded the video file shows 01:51:42:05 and the audio file shows 1:49:05:00. And as you can imagine when I put it all together the synch at the begining of the movie was off. What did I do wrong or what can I do to fix it??? Also I choose forced film because dvd2avi showed 99% FILM as per the guides. I am using DVDMaestro version 2915a.
Is there anyway to play the movie in DVDMaestro so I don't have to wait 30 minutes to see my out of synch final product.
Thanks!
hmm ive seen a similar problem ages ago when i was making VCD's, it turned out that i was running it too fast and it was burning on the fly.. i guess my old drive couldnt keep up so it dropped audio.. not sure if this is any help at all but just thought ide mention it.
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 07:27 -
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 19:27 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:10 -
Cinematize synch problems
By whoisquilty in forum MacReplies: 4Last Post: 5th May 2008, 18:34 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 22:22
