I ask a few friends if it was possible to burn a cd without a dvd burner, and all the answers was no.
I was surfing the web and came apon something called "DVD Copy Pro" http://www.dvdcopypro.com It is a software that allows you to burn a dvd without the a dvd burner, infact that is the first question on there Fao section of the site.
http://www.dvdcopypro.com/faq.html
It says all you need is a dvd drive (which i see is at an all time low in price) and a cd-r installed.
What i want to know is if this is possible to burn a dvd this way, or if this is just a scam.
Also, if anyone here ever tried this method, please let me know if it worked. Thanks alot
FYM.
Results 1 to 9 of 9
Using those software you are creating vcds on CD-R/W. No DVDs.
Wow! that was a speedy reply (fast than when your in chat) lol.....thanks alot.
Do you know if the quality would decrease alot? I have a standalone samsung dvdm101 and i know its kinda fussy when playing vcd's -
it dose work and you can play them in you stand alone dvd player. its not dvd but it is close if you encode to svcd but most dvds are like 2 hours long and a cd only holds like 35 to 40 minutes so if you don't mind getting up a lot to watch a movie then go for it. i hope you wasn't planning on buying DVD Copy Pro because you can find guides on this site that will tell you how make svcds and it all freeware.
lmao
No way, i would look all over the net until i found a priated version. (sorry is saying that is not allowed) 30-40 minutes? i thought a cd was about 74 minutes but i guess that only applies to music. I will look on this site for alternative methods to dvd copy pro. thanks alot. -
If you choose VCD, you can fit near 80 min on a 80 min CDr/w.
If you choose SVCD, you can fit about up to 60 minutes on a 80 min CDr/w with GREAT quality if you use for example dvd2svcd. -
well you can put 74 or 80 minutes of video depending on you cd if its a 650 or 700 meg but you would have to make vcd which it like a vhs movie and svcd is more like dvd and thats why you can only put 30 to 40 minutes on a cd
why pay? They just give you tools that are freely avalible. and guides are avalible here. The tools are on the tools page.
@ GREG
Your right, there is no reason to pay. for all i know they could have been using programs from this site.
It was just an example to see if it can be done.
What the site failed to mention is that you woul djust get a vcd, or svcd.
i thought you were burning a dvd to get a dvd without the dvd burner which i was wrong about.
Winx dvd copy pro
By jajabong in forum Authoring (DVD)Replies: 5Last Post: 29th Oct 2011, 00:37 -
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 09:34 -
About non blu-ray DVD burner to copy the HD video
By coody in forum Authoring (Blu-ray)Replies: 24Last Post: 11th Aug 2010, 21:57 -
DVD Burner Freezes When I Try to Copy a DVD
By w6rlf in forum DVD RippingReplies: 5Last Post: 7th Dec 2009, 14:41 -
Dvd Burner Wont Copy
By Catman209 in forum DVD & Blu-ray WritersReplies: 12Last Post: 16th Dec 2007, 00:35
