Any MSI users there who can tell us the current status of the card?
how are the new drivers working? Are they working at all? Have they matured anything at all? (please also specify your system)
please, any input will be useful, as I'm thinking of buying one of these cards. Also, is this true? - the tv@nywhere does not have antenna connection?
thanks
/bomba
Hi, i just purchased the card and i'm having problems with the driver on the cd and downloaded from msi website. did/do you have this problem. Can you tell me the version code of your drivver (cx88vid.sys).
thjavascript:emoticon(':-?')
http://www.vcdhelp.com/forum/images/smiles/icon_confused.gifanks -
hi in responce to you question over antenna on this card it use's an "f connector". It's a very good tuner card (the only problem i had with it, was i could not get audio to work every thing else perfect other than that can't fault it)
How to encode anime to 10bit x264?
By Deadly9000 in forum Video ConversionReplies: 45Last Post: 12th Mar 2012, 09:10 -
Status of SVCD2DVD
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Feb 2010, 19:35 -
bt conexant 878a darker band on bottom has appeared
By video_magic in forum Capturing and VCRReplies: 0Last Post: 3rd May 2009, 22:41 -
msi motherboard replacement
By mixxerr in forum ComputerReplies: 10Last Post: 21st Aug 2008, 00:09 -
Which is better? Conexant CX23881 or Phillips TDA8290, TDA8275 Chip
By ffxdean in forum Capturing and VCRReplies: 3Last Post: 15th Jul 2007, 20:55
