Hi..
I have a major problem with TMP...I downloaded movies off of Kazaa and I can only play them on Divx..I am trying to convert them so I can watch them on a VCD...what is the best method to do this...I have tried using TMP to convert them (I have the Divx codecs installed) but all I get is a black screen.
Jon
I have tried raising the direct show priority but now instead of a blank screen all i get is "avi not supported" message. What am i doing wrong?
Okay I have changed the setting to a 2 priority and downloaded and installed all the codecs now when I convert the Divx/Avi file all I see is a black screen....what I am doing wrong?
Jon
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Restoring capture from Windows Movie Maker .tmp file
By markm96160 in forum Capturing and VCRReplies: 3Last Post: 17th Nov 2008, 14:37 -
agk tmp folder and disapearing explorer and/or error message
By snowbabe in forum DVD RippingReplies: 4Last Post: 29th Jan 2008, 08:01 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
