  1. Hi. I just talked to Philips customer support and they say that this unit IS firmware upgradable. Does anyone has the regionless/microvision etc. fix yet?
    Thanks.
  2. Check out www.firmware-flash.com
    great forums and firmware info for all your cd/dvd rpm and recording needs
  3. Err.... This is regular DVD player btw. With Slot loading and stands horizontally. The tech support btw says that you update it using a CD.
    Here is the link of the player:
    http://www.consumer.philips.com/global/b2c/ce/catalog/product.jhtml;jsessionid=UID4DSR...Id=DVD580MT_17[/url]
    Looks cool.
