When i try to view a SUCESSFULLY made MPG ( SVCD Plays perfect on my home DVD player ) with TMPGE using MEDIA PLAYER I get this error:
Unable to download an appropriate decompressor.
How do i fix this? I've downloaded the " Nimo Codec pack ".
THANKS.....
Have you got an mpeg-2 codec installed. If not install the powerdvd demo, link in the tools section.
i would suggest to install winDVD or powerDVD which gives you the mpeg-2 codec...
however, even if you do this, trying to play a burned SVCD mpeg from a SVCD disc on media player will NOT work...
media player only play non-burned SVCD mpegs.....once you burn it, the only way to get media player to play burned SVCD mpegs is to strip all the headers, etc.. with vcdgear and put it onto the harddrive...then media player will play it...once you burn the .mpg file and nero adds all the headers, media player will never read it (does NOT apply to VCDs) -
I've already got WINDVD installed. Im trying to go into EXPLORER under the folder i placed the move.MPG file using TMPGE and VIEW it BEFORE i burn it to verify it WORKS......
hrm..if you've already got winDVD installed and this .mpg is pre-burned, then i have no idea why media player doesn't work...
however, winDVD can definitely view SVCDs, so you can load the .mpg up in winDVD and verify your rip
Windows Media Player Error message
By visjds1 in forum MediaReplies: 2Last Post: 10th Nov 2008, 14:15 -
Media Player Classic Error
By bobxtraz in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2008, 01:56 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 13:53 -
CopytoDVD states media does not have enough space - error message
By marke67 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Sep 2007, 05:52 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
